Results 1 to 10 of 10
Thread: 1991 Ram 50 intermittent hard start condition
    Twin Falls, Idaho
    Question 1991 Ram 50 intermittent hard start condition
    Hello all!
    My '91 2.4L is having an occasional hard/no start issue. CEL comes on, but usually clears after I've turned off the truck. I've pulled code 15 and code 21 from the ecu, so I have a general direction to look in, but I cannot for the life of me figure out what Mitsubishi is talking about when they say "Motor Position Sensor". The TPS and Coolant temp sensor I can find, but nothing for an MPS.
    My dad bought this truck new in 91 and it's been passed on to me, so getting it fixed up will mean a lot to me.
    Thanks for any help or advice you can give!
    North Dakota
    Us 'mericans call it a crankshaft position sensor...
    Twin Falls, Idaho
    Quote Originally Posted by Fingers View Post
    Do you happen to know if the 2.4L has one? I cannot find such a critter in any of the usual parts houses.
    Perhaps it's in the distributor?
    Ca
    1993 Dodge Ram 50
    Yes, both the "cam and crank position sensors are in the distributor.
    i will see if i can get a pic to upload...
    the plastic disc contains the two optical sensors- silver disc is trigger wheel-.
    Twin Falls, Idaho
    Claych- do you know if anyone makes a rebuild kit for the distributors, or is it a replace-the-whole-thing kinda deal?
    Pukwana, SD
    I have a 2.4 distributor out of a 92 2.4 that had head issues to get it going. I’d need to look it over to make sure it’s worth your time.
    Quote Originally Posted by Recon1342 View Post
    Shouldn't need either unless major components are physically damaged/broken/corroded beyond repair. Just disassemble, clean/lubricate, reassemble, and maybe replace that sensor module.
    Speaking of clean/lubricate, if those sensors are optical I wonder if it might suffice to just clean up the sensor eyes and trigger wheel? Maybe someone sprayed lubricant in there that gunked those up, attracted dust, etc.
    Ca
    1993 Dodge Ram 50
    Recon,
    I have been unable to locate individual parts for 4g64 2gen distributor.
    After tearing down a couple of these, the screws that hold the harness plug
    to the dist body are installed with RED loctite so heat & care must be used on teardown.
    I personally would recommend a " rebuilt " unit complete as the optical sensors could be dirty
    but the sensors are so robust that the dist bowl would have to be wet with oil/contaminant
    for a no-sync condition to exist ( which could cause your issue).
    These optical sensors are VERY stout and seldom fail.
    So the % are with you to get a good sensor with a reman dist.
    ~claych
    Pukwana, SD
    Sold the used one I had
    Twin Falls, Idaho
    I pulled the dizzy cap and cleaned up the corrosion on the terminals, as well as the rotor. Fixed the problem, so I have new ones on order.
