Results 1 to 5 of 5
Thread: Carburetor rebuild guide
    Iowa
    1984 Dodge Ram 50
    Hey everyone, I've had a carb rebuild kit for about a half a year kit and still haven't done anything with it, so I decided to stop struggling and putting it off and reach out. My problem is I have absolutely no idea how to get the stock mikuni off the intake manifold. I tried to follow my Chilton manual and remove the bolts but I honestly don't think that I had the right ones, and of course that's the only step that doesn't have a picture in the manual. Any idea what I need to remove to get the carb off? and possibly where I can find a better manual? (Truck is an 84 with the G63B and stock 2 barrel Mikuni)
    Hello nitro, a Mikuni rebuild is quiet the project but you can do it ~ the carb has FIVE hold down bolts the 5th a small short bolt front driver side of carb ~ drain some 1/2 gallon coolant before removing the carb
    Check out my threads & photo albums of Mikuni Rebuild
    Good Luck ~ George
    Iowa
    1984 Dodge Ram 50
    Alright, thanks. I'll try it out my next day off
    Iowa
    1984 Dodge Ram 50
    update, tried to get the carb off today and it turns out the bolts weren't the issue, i took off all the correct ones in the first place. It seems like the carb is stuck down to the manifold.
    Big flat blade screwdriver with a twist will get it off SLOWLEY there is at least one spot on the carb with a metal lip big enuff to pri on...
