Aha, that "boomerang" bracket in your first photo is meant to go on top of the valve cover, to anchor the cable housing there if it was coming at the carb from the exhaust side as stock. It won't be used with the cable coming from the intake side as you've got it. The linkage kit for a Mazda pickup (Redline Weber part no. 99007.675) will include the brackets and curved bellcrank I'm using:
- https://www.carburetion.com/Products...Part=99007.675
- https://www.piercemanifolds.com/MAZD.../99007.675.htm
See here for tips about uploading and inserting pics:
http://www.mightyram50.net/vbulletin...ips-and-tricks
