I didn't see anything on the old valve stem that looked like marks or damage. There were no shims or washers, only springs on the rail shaft.
Should the lifters be pumped up with oil before installation, and if so how long will they hold oil? The installation instructions call for that, and if so my installation procedure would possibly need to change depending on how long they hold pressure. None were pressurized when I removed them.
Thanks
