Results 1 to 3 of 3
Thread: Clutch pedal sqeak
    MIAMI, FL
    Clutch pedal sqeak
    Just purchased a 95 MM and noticed that my clutch pedal began to squeak, has anyone dealt with this issue? Might just spray some lithium grease on clutch master to see if it quiets down.
    thanks
    Probably not the clutch master cylinder itself, more likely the pivot points on the pedal, the connection at the top of the pedal where it connects to the master, and/or the pedal spring.
    MIAMI, FL
    Hey yeah it was the pivet pin where cable connects by the gas pedal. Sprayed lithium grease on it and it went away. Thanks for the response
