https://www.ebay.com/itm/184650371240
you need to pull the plug out and put yours on it. or just return it and get the one above.
Yes i was thinking that could work but will the wiring match up as well as the specs? The mechanic was saying the colors were different as well but the wiring does seem to be held in place by a couple screws so it could easily be swapped onto the purchased distributor. I would return it and buy the one above except that would take time which i cant spare a whole lot of
Thanks for your response mate
