Any 2-bolt fuel pump block-off plate for a Big Block Chevy or Big/Small Block Mopar/Ford should work, but the 4-bolt plate for a Small Block Chevy won't.
I'd recommend getting an alloy one, just in case you need to file/grind the edges down slightly to fit, as I needed to do for mine.
