Or you could spend $30 on a jet valve eliminator kit.......
Which doesn't eliminate issues w/ jet valve heads (aside from the jet valves themselves), such as increased propensity to crack the thin walls around the jet valve inserts, due to differing thermal expansion of the aluminum head and steel jet valve/eliminator inserts.
