the pic in previous post the return line and line to carb are actually touching the bottom edge of bracket, i did not like this and did not want to take a chance on kinking the line if i just bent it by hand so i clearanced the braket for the lines.
DSC09744.jpg Here the back edge of bracket notched for fuel lines.
DSC09745.jpg Here before i marked and drilled the holes for mounting the bracket i was checking for plumb or get as close as possible. i did this since this is a rotory pump i wanted to give it the best chance possible of survival.
