Good Points Sub & FMS
Some good news today ---> SFX Performance https://www.sfxperformance.com/ finally contacted me by Facebook messenger ---> they were shut down by the big freeze ice snow storm that hit their Texas location the other day ---> they will ask the cat manf factory (DEC..?) to use the lowest priced method of shipping to Hawaii if we do buy their rear cat ---> SFX is only a distributor & so is ebay's BIG RED but big red has not replied to my messages..!
If I can get some exh gaskets from O'Reilly's then I would like to try using the lift at Five O Motors and some heat, PB blaster & rattle gun to loosen the exh manf to pipe fasteners and the rear flange joint fasteners too ---> then sometime, try removing the rear cat assy for inspection and access to the front canister cat IOT remove it from the exh manf...
Eventually, am hoping this thread might provide catalytic converter solid info & source of supply ---> possibly get the truck running normal again which could/would help members with similar engine issues...
