Results 1 to 3 of 3
Thread: 95 MM electrical connector
    Salt lake city, Utah
    95 MM mystery electrical connector
    Have a mystery connector i cant find other end to it. Need some help to identify
    It's not plugged into anything, it has power to it, it has 2 wires one is green with orange, other is yellow with white or grey marks.
    Can you post a pic of the connector and tell us where it's located and what it goes to?
    Also, bear in mind some connectors in the standard wiring loom may have been left unconnected at the factory -- e.g., for optional/other equipment specs your truck didn't have.
    Seattle, WA
    Quote Originally Posted by Pmoser1 View Post
    If the 95 dash harness is the same as in a 92, the GO/YW wire connector plugs into the seat belt/key remind buzzer mounted just above the hood release knob. A PO probably disconnected it so they could listen to the radio with the door open.
