22mm or 24 I think
OSH hardware has good craftsman for cheep.
Engine oil pan drain plug is on the front right side of the engine when sitting in the drivers seat. You can see it with the hood open looking down.
Always loosen the fill plug before draining any fluids. You can run into trouble otherwise. If you can't remove it then your screwed. Then you have no oil with no way to fill it.
If you can you can take back the manual.
We have it here.
http://www.mightyram50.net/d-50/Fact...-1983-1993.zip
You also might want to look though the manual and source info section.
Reason: Fixed broken link
