Results 1 to 3 of 3
Thread: Radiator Rx?
    Pomeroy, WA
    1989 Dodge Power Ram 50
    Radiator Rx?
    Hey People,
    Having some heat from my '89 Ram 50 2.6L.
    Flushed myself block & rad and new thermostat.
    After a year running hotter, not pegged. Fan clutch feels wimpy,not easy to physically lock up. Crusty, flaky on top of rad tubes. Some coolant loss, no sign in eng oil.
    So, a flush with citric or cascade? Load & higher ambient temps seem to affect the temp. Any clear route for a new rad once I rule out the outside variables? Thank you all.
    Pukwana, SD
    Check you radiator cap they can play some screwy games.
    If not done yet try:
    Prestone (or any good brand) cooling system FLUSH
    Use 50/50 premix coolant ALWAYS (it's made with distilled water & the correct 50/50 mixture cannot ever be screwed up) unless you use..?
    Check ignition timing too advanced will cause overheating
    Hold a piece of stiff cardboard against the fan blade with engine at idle ~ if the blade can be stopped then the fan clutch is NO GOOD
    Try to avoid aluminum & plastic radiators
    Good Luck
