I have a 95 MM, threw a rod bearing and sat for 6 months. Got her back from someone, long story. but Its refusing to start at all.
Replaced timing belt and balance shaft belt, fuel pump, battery grounds, and starter. I know this isnt the first thread but I noticed other crank no start threads are due to spark or fuel. But I pulled the fuel like to the rail, has a ton of fuel pressure. Very strong spark at the Dist. Tried starting fluid messing with plug order on the dist ect, and just no start. Any ideas?
Also pulled intake/fuel rail and cleaned it all out, incl egr, which was plugged with carbon big time. Ive seen that sometimes its the ecu, and I bought a new ecu just a few minutes ago, I didnt check the current ecu, but I cant return this new one, so regardless itll have a new ecu. Does anyone have any idea what it could be?
Timing marks and everything lined up when it was timed, but itll just crank and crank with no start. Id love for anyone to put in some advice, im loosing my mind over the past week trying to get her started again. Replacing wires and plugs soon, if I cant figure it out im going to take it to a shop but id love to not have to do that and spend more money than id like to.
