Results 1 to 25 of 27
Thread: Cleaning stock Mikuni carb
    Seattle, WA
    Quote Originally Posted by MidnightPass View Post
    I am not sure exactly why it was sitting for so long, nor how long it was sitting for. I know it sat for at least six months, but other indicators say it was longer than that even. I was told the guy I bought it from was selling it because the carb needed work and he didn’t have time to work on it. It Did not run for at least those 6 months though. But from the smell of the fuel I drained from the tank, I would say it sat for even longer than that.
    Hopefully the PO is right and it just needs a carb and fuel system cleaning. How did the rest of the engine appear and test? Okay I hope.
    Florida
    With the carb how it is, I was able to run the truck off of ether for basically however long I wanted, but the engine sounded beautiful ��
    Florida
    Also, I figure it should be a good thing to mention, the truck would crank up and run for about 2 seconds then die and not start back up for about 2 to 5 minutes… Then do the same thing again.
    Seattle, WA
    Good to see that it will fire up and run even briefly. Still, I'd test the compression just to be sure it doesn't suggest another reason it was parked. Not sure about the failure to restart. My first guess would be an ignition problem (coil, ballast resistor, distributor, timing). Check what you can before replacing parts and especially the coil/distributor wiring. The PO might have tried to get creative with the ignition system, too.
