Originally Posted by
geezer101
Don't put the cable bracket on the firewall - the engine moves around on and off throttle, the firewall doesn't. It will do some scary things. And it looks like the cable already runs along the only place you could fix the bracket to. Xbox's idea isn't bad. You could drill a hole where the mounting stud should be, put a washer and rubber seal on a bolt and push it through from the inside, drop on another rubber seal and washer from the outside and use a flare nut or nylock to clamp it all together.
