Doctorates Degree
*I've just discovered injector pulse generators really cheap online. Only problem would be waiting on one to be delivered if you're in a hurry. There are also crude injector cleaner kits that simply connect to a spray can cleaner and hook the injector to the car battery - they look like they have the potential to spectacularly erupt into flames but they also might keep the injector open long enough to blow any varnish or particles out of them.
