Results 1 to 3 of 3
Thread: Pressure rating for inline fuel pump
    Lincoln, NE
    1993 Mitsubishi Mighty Max
    I'm trying to replace my fuel pump, and decided I'd try going the inline route to save time and effort. I found a thread here from 2013 that listed the fuel pressure between 38-53 PSI, but the ones I can buy locally are either 3-5 or 5-10 PSI. Is that other number correct, and I need to look for a higher rated pump? I appreciate any assistance, thanks.
    Going by the year you've stated on your user array your truck will have either a 2.4 4G64 or a 3.0 V6. Both of these engines are running fuel injection - you will need a high pressure fuel pump. The pumps you are looking at are suitable for carbs.
    Lincoln, NE
    It's the 2.4l. I've been researching all morning, and I think I've found one that should work on Crapazon. It runs up to 300lph/80gph at 43psi. Thanks for the response. I'm ordering it now and I suppose I'll see next week if it works.
