Results 1 to 25 of 28
Thread: 1995 MM bought DOA needs work!
    New York
    1978 Mitsubishi Mighty Max
    delete
    New York
    delete
    Quote Originally Posted by atownbrg View Post
    is there any reason why Mitsubishi would have used 2 different tank setups for the exact same build of truck?
    I can only speculate, but perhaps the large-capacity tank could have been an optional/package upgrade on the LWB trucks that had room for it?
    If not, and if the yard did pull that tank from an otherwise matching build/year, maybe that truck's PO ran into the same NLA tank issue and had already retrofitted a SWB tank from another truck?
    New York
    delete
    New York
    Dumb question, and you've probably already tried but will it work if you use the rear mounting holes and then work on the front support? It should bring the filler neck into alignment so at least you don't have to mess with the filler tube. The return and pick up lines are easier to adapt if they need to be longer.
    New York
    delete
    Add spacer washers to the tank mount location to give you a little extra wiggle room... should solve part of your problem with the lines.
    *there may actually have been spacers there in the first place
    Less gas go faster ~ carry on bro
    New York
    delete
    New York
    delete
    It's prolly a BSP standard, since they used that for other pipe threadings. 37-degree flare appears to be a JIC (Joint Industry Council) fitting, not JIS (Japanese Industrial Standard) -- which latter uses a 30-degree taper with BSP threading.
    Not clear if you mean "soft lines" as in rubber lines with attached end-fittings or workable metal; just don't use copper tubing for the latter -- vibration work-hardens it, causing it to crack eventually. Cupronickel (e.g. Cunifer™) would be suitable, typically supplied for brake lines.
    New York
    miami, fl
    1991 Dodge D-50
    i wouldn't even go thru all that crap. You must have the time to waste
    if the hose needed extending, I'd cut that hose and use the appropiate length tube/correct o.d. + clamps
    500hp street nissans live fine with fuel hose, slid over & clamped to tubing
    New York
    If you go with splicing pipe into the middle of the stock hose, take care to use FI-style hose clamps, not the typical worm-drive clamps, which don't clamp evenly around their circumference and thus can leak under high pressure. FI clamps are smooth bands with an overlapping section at the open end, and "ears" where a screw passes thru one ear to a captive nut in the other ear to tighten the clamp, like so:
    WILL SPRING CLAMPS WORK OK ? WHAT TYPE CLAMPS ARE ON THE GAS TANKS NOW ? LOOK HERE: http://https://hosetips.com/spring-hose-clamps-vs-screw/
    Spring and worm-drive hose clamps are both fine for carbureted engines, but unsuitable with fuel injection where high fuel pressure makes them prone to leak.
    miami, fl
    1991 Dodge D-50
    good tip on the clamp. Oem nissan type shown here, they last forever
    may need bigger diameter for that thicker mitsu hose. Grab em(same type) from oem external tranny cooler lines at junkyard
    lloootttsssaaa folk run worm type tho. Supplied with most new fuel pumps
    New York
    delete
    I will get some good quality ones as pictured or use some Oetiker single ear clamps. Those are used by oem too and should suffice. I may have some around for 5/16 line, I'm pretty sure the 15.7's are specified. So the square tube the guy had is only 16 gauge (1/16" ) not the 1/8" we talked about. even though theres probably only going to be 150lbs max on it i may get something else because I only have a stick welder and thats pretty thin!
    Junkyards suck in my area bigtime
    Harbor Freight sells tiny stick welding electrodes 5/64" or the like should work on half way clean metal start with 65amps
    New York
    delete
    Is there a way to retitle the thread, I have now realized I have other questions not about this tank that I have but don't want to start an individual thread on each one!
    Mods can do that for ya; what do you want the revised thread title to say?
    New York
    delete
    Thanks SubGothius, how about
    Done.
