if it's sucking down an over flow bottle of water after it cools off then I would start to look at a head gasket problem. But since it's winter it could just be a cold exhaust pipe. If you put a vacuum gauge on it and the needle whips back and forth then you can have a problem. But the best thing to do is watch the coolant use.
