Results 1 to 17 of 17
Thread: To Turbo, or not to Turbo...that is the question
    Savannah, GA
    rickdees posted the yota engine, a good ole 4age. It would be pretty easy to build the manifold id think. But what about the thermostat housing and coolant passage in the manifold? Unless your planning on cutting up a stock manifold, I could see that being a challenge.
    Quote Originally Posted by LethalEthan View Post
    We would need to machine a block for the t stat. Or cut and weld the stocker to fit. That would be the easy way out. Then just fly cut down the surface when done. But it is totally doable.
