Results 1 to 4 of 4
Thread: Headers and Cams
    Coal Township PA
    Headers and Cams
    I’m looking to get a little more power out of my 2.6 while I’m getting the transmission rebuilt. I heard that the pacesetter headers don’t help performance much, but I cannot find where to get the dg headers. Also, are there anymore companies making street cams for these things? I wanted to just do a 4g63t swap, but that’s a bit out of my price range right now. If anyone knows where I can find stuff, or has suggestions for power, let me know.
    Sorry that happened Cole a muffler shop is checking how feasible & how much work it will be to install a Pacesetter brand from Summit Racing factory replacement direct fit catalytic convertor on my truck they will use the original inlet pipe welded to the new cat a lot of extra work coz it does not fit as it should yikes yeah $$$
    Seems like PaceSetter may be out of business, if that's the same PaceSetter Performance Products in Phoenix that Google is saying has "Permanently closed", and all the vendors like Summit/Jegs/etc. show their items as "Out of stock" or "Call for availability".
    However, last post in this thread a couple months ago says DG Headers is still making theirs and provides a contact email:
    http://www.mightyram50.net/vbulletin...ll=1#post85415
    Thanks for that info Sub it could very well help many folks including me ~ with my wife's help I will try fitting the Pacesetter cat ~ slots in it's inlet pipe connection need to be drilled or burred out at the proper C/L distances for the two spring exhaust manifold bolts to pass through the slot & will need two ss bolts washers nuts to install the outlet side (need to find the outlet gasket I have somewhere too)
    Thanks Again Sub
