Results 1 to 7 of 7
Thread: Another oops.
    Jacksonville Fl
    1992 Dodge Ram 50
    Another oops.
    So as I was drilling out a broken screw in the fuel line connecting to the fuel rail I ended up drilling a hole into the fuel rail... so my question is any way to fix? Any interchangeable parts? Any leads to where I can find a fuel rail? Anyone selling a fuel rail?
    Solder it up or if you are good with a tig welder
    Off the truck, and well cleaned
    TIG weld pay its worth fixing ~ don't feel too bad ~ I did an opps to my radiator's fins with the wand at a DIY car wash duh
    Nevada
    1991 Dodge Power Ram 50
    Buy another rail. Dont try to patch it up. Otherwise you and your car will randomly go up in flames one day.
    Quote Originally Posted by B-Line View Post
    +1. And a used rail will be cheaper than getting one welded up and pressure tested.
    not if its done well and pressure tested before use
    you can pressure test it at home, its not a major. Tig weld or braze/silver solder would be an appropriate repair if a replacement is not available
    costwise, that depends on whats available to you, you would use like $5 of rod and gas and maybe 30mins for either of those methods if you have the tools, if your buddy has the tools then throw in another 30mins of driving and a 6pack.
