Results 1 to 6 of 6
Thread: Key code
    Tucson, AZ USA
    Key code
    So I just stumbled across an interesting tidbit on the MMM group on FB, that I haven't found any prior mention of here on the forum:
    Apparently the code to cut a brand-new key is stamped on the passenger side door lock. Can anyone confirm this? Gen1 or Gen2 or both? Seems like it may be a 4-digit code, possibly with a letter prefix.
    I'd check it myself, but I literally just weeks ago reinstalled my passenger door trim card with all-new retainer clips, would hate to have to bust a bunch of those again, and/or damage any more keyholes in the card that they slot into, just to find out. Reckon someone here must already know the answer, or have a truck with the passenger door card already off who could check.
    I still have one original MM key ~ there is a # stamped H2489
    But same with my door card its intact not gonna tear it open :^))
    Mitsubishi key blanks are still available from https://www.mitsubishipartscentral.com/ BUT I don't know if a key can be cut with using just the code #
    Seattle, WA
    1988 Dodge Power Ram 50
    I have a pair of lock housings I removed from a Gen 2 truck years ago. Needed some internal pieces. I didn't mark which came from which side, but one is stamped with a five-character code, H0026. The other is blank.
    Both housings had the same three-character code (U22) on one side. Probably to indicate they're a matched pair.
    Riverside California
    you are correct! the key code is on the passenger door lock, it is a 5 digit code starting with a letter and 4 numbers. I too am looking for the curtis industries code book.
    I am in Riverside California, when I find who can cut keys with the key code I will post it here. Does anyone have the code book? I have a curtis key cutter model #15 and the code book for Suzuki motorcycles from 1985.
    Inwood WV
    1991 Mitsubishi L200
    4D56-T
    The H2489 is the code for YOUR key, if you go to a locksmith, they can look it up (will charge for lookup) and cut it from the saved keycode. As you mentioned, this code is stamped on OE keys
    Quote Originally Posted by d50Lewis View Post
    My local locksmith Norvac has cut starion keys for me from the code on the OE key
