Bachelors Degree
I did the big brake upgrade on my 89 Montero and can no longer run 15" wheels. I run 18's now. As long as you are ok with running a taller wheel then you will be ok.
I also grabbed longer Stainless Steel lines from these guys to accommodate the added length.
https://blineperformance.com/
Nice
Do you have a link to the exact line you purchased?
