Results 1 to 9 of 9
Thread: Rebuilding a Bosch VE injector pump (mitsubishi ZEXEL pump)
    Come with me as i work on an L300 mitsubishi van with 4D56 engine and Zexel ( style of Bosch VE) injector pump.
    The problem - fuel leak. Appears to be from rear of pump in a few places around the distributor block (square section on the back)
    Probably just a seal/Oring has shrunk over time. Pump is otherwise fine, no noises so the plunger is probably ok.
    This is the information i am following
    http://www.delica.ca/manuals/L-400%2...uel_system.pdf
    removing the pump
    Next, dismantling the pump
    Diagram and torque specs
    Nice write up
    My DIY timing tool
    i used an m8 1.0 bolt. Drilled through with a 4mm drill bit
    some 3mm rod (titanium because thats what i had) and a bicycle cable sheath ferrule heated and pressed onto one end
    some 10mm diam stainless steel tube. silver soldered to the bolt
    Then made a clamp out of some scrap 1/2" plate and an allen bolt i had laying around.
    Dial gauge is just a cheap aliexpress one, but does the job well enough for my stuff (already had it for my bicycle wheel truing stand)
    Great thread so far. Keep it up.
    Unfortunately the last half of my video of this got corrupted on the card, but you should have no problems following along with the official Bosch video
    Southern California
    1985 Mitsubishi Mighty Max
    4D55-T
    This is still a super helpful thread. Thanks for posting it and all of the contributions.
