Results 1 to 2 of 2
Thread: Dead miss cylinder 2. HELP!!
    Missoula,MT
    Hey everyone! Hoping someone can help out here. 1992 Mighty Max, 2.4L 5 speed manual, rwd.
    Engine light is on and the code came up for a dead miss on cylinder 2. Mechanic adjusted timing, said voltage is good, and compression to all cylinders is 150. He was at a loss for what could be causing the misfire.
    I have done:
    -New plugs and boots
    -New O2 sensor
    -New oil and filter
    -New Distributor and rotor
    -New fuel filters (both)
    -Cleaned injectors
    -Cleaned valves
    -Cleaned EGR
    If you have any ideas, let me know! Ran really smooth before this!
    swap a plug from another cylinder into #2
    if no fix
    swap a wire from another cylinder onto #2
    swap your old cap back on
