Results 1 to 5 of 5
Thread: Mass Air Flow / Hesitation Issue HELP
    Asheville, NC
    1990 Dodge Power Ram 50
    4G63
    Hey all. First timer here. I just recently picked up a project truck in my 1990 Power Ram 50.
    It hasn't ran in a little over a 6 months. Initially it wouldn't start. I assumed it was fuel related so I replaced the fuel filter and flushed the lines.
    Then, I discovered some slappy had swapped the vacuum lines on the EGR Control Solenoid and the purge solenoid. So, the EGR valve was staying open all the time. Once I fixed that, it actually started with a VERY rough idle.
    So, I then checked the MAFS:
    - When it's plugged in; rough idle and stall.
    - Manually choke the two extra ports on the MAFS; it idles fine but hesitates badly when accelerating quickly and will eventually stall... but revs fine when accelerating slowly.
    - Unplug it; Idles great but has the same hesitation but a little better. Still revs fine slowly.
    Other notes:
    - Pulled the plugs they are dry fouled, so I'm assuming it's actually running rich but they could have been fouled for a while. I'm replacing the plugs today.
    - I haven't pulled the fuel rail and cleaned the injectors yet.
    - Checked the TPS and it's fine
    - Checked for vacuum leaks and cant find one anywhere
    - I need to check timing but attempted to manually advance the spark. It seemed to help a little but not much
    Any ideas? I'm leaning on a bad MAFS but those are hard to find and NOT cheap. Could it be anything else?
    It sounds like it's off by 1 tooth on the belt timing. The mark is not the flat of the head like you would think. It's actually under the head by 1 tooth.
    Has it ever run good for you?
    The more info you give us the better we can help.
    Asheville, NC
    4G63
    So, it turns out it was actually the fuel pump. I replaced it and it runs amazingly well 🙂
    Nice work Always difficult to diagnose a fault without being able to see it in person.
    Merry Christmas
