Doctorates Degree
Stick to NGK's. It is weird how some engines prefer a particular plug. Fords run autolites without grief. The Accel coil might be a little on the high side of recommended resistance. I've heard of guys having issues using them (burning out rotor buttons, distributor caps etc) The stock 'solid state' transformer coils work very well compared to the oil filled cans and are relatively cheap to buy.
