No relay in the 1st gens, it's all wired direct to switch.
Probably you want to pull the switch out, apart and clean the contacts up. They might want some bending back into shape too. The fixing itself will be the switch sometimes clicking into place and other times not
Good time to check the wiring and grounds at the headlight end too
