Results 1 to 7 of 7
Thread: 92 dodge ram 50 body lift questions
    Syracuse oh
    1992 Dodge Ram 50
    Just was wondering if anyone had any links for body lifts for a 1992 dodge ram 50 and what all I would have to do to add about a 2in one
    eBay search l200 lift kit out of Australia likely maybe Thailand.
    L200 is the same truck
    Nevada
    1991 Dodge Power Ram 50
    Yours a 4x4?
    All you can do is a body lift. You can make spacers out of Perlin plastic. Just make sure they are all the same. Then a longer bolt. Just keep in mind the steering shaft is the main limiting factor. a 2 inch lift looks good.
    1993 Mitsubishi Mighty Max
    Performance Accessories used to make a 2" and 3" body lift for 2nd Gen RWD.
    Years ago I searched all over for a 2" kit. I ended up buying a 3" kit and it was the last one that seller had.
    They do list kits for Toyota trucks from our years though........
    ed; fixed link
    Syracuse oh
    1992 Dodge Ram 50
    Mines 4x4
    Nevada
    Best you can do is max out the front torsion bars but that makes for uneven wear and blown CV’s.
    otherwise body lift or get crazy with a solid front axle build.
