92 dodge ram 50 body lift questions
Just was wondering if anyone had any links for body lifts for a 1992 dodge ram 50 and what all I would have to do to add about a 2in one
Masters Degree
eBay search l200 lift kit out of Australia likely maybe Thailand.
L200 is the same truck
B-Line Performance
All you can do is a body lift. You can make spacers out of Perlin plastic. Just make sure they are all the same. Then a longer bolt. Just keep in mind the steering shaft is the main limiting factor. a 2 inch lift looks good.
Junior
Performance Accessories used to make a 2" and 3" body lift for 2nd Gen RWD.
Years ago I searched all over for a 2" kit. I ended up buying a 3" kit and it was the last one that seller had.
They do list kits for Toyota trucks from our years though........
ed; fixed link
Bachelors Degree
Best you can do is max out the front torsion bars but that makes for uneven wear and blown CV’s.
otherwise body lift or get crazy with a solid front axle build.
