Freshman
New truck no fuel getting into carb
Hi y'all just picked up my 87 2.6 litre from and auction, it'll fire with ether or by pouring fuel down the carb, no fuel squirting out from carb at all i bypassed the tank with a gas jug and still nothing. Any help at all would be appreciated.
1987 ram 50 2.6 auto
Masters Degree
Sounds like the fuel pump
mechanical one? could be the diaphragm has split
when you bypass it, i assume you are running a new line from the jug to the pump.
New pumps are available, about 60 bucks usd
Freshman
It's sucking fuel from jug
Freshman
Running jug into inlet to the fuel pump and yes it's a mechanical pump
Freshman
Pumps making good pressure return line has enough pressure to try and push my thumb off when it's cranking and it's capped
Masters Degree
Is it getting into the carb?
could be blocked line from the pump to carb, or the float in the carb is stuck closed
Freshman
It's getting up to the carb I'm not too familiar with these carbs I was reading about a fuel shutoff? Not sure if that's something that can be bypassed or maybe the carb just needs to be rebuilt?
For stuck float ~ try tapping on the carb at the front above the float above the fuel inlet pipe ~ use a small hammer or large screwdriver handle ~ don't break it but give it several good punches right in the eye ~ got anything that vibrates strongly (?) might try it too
Freshman
My guess was stuck float I tried tapping on it and it didn't get me anywhere. Fuels getting to the carb and is coming out of the top return line but not actually flowing out of the carb. I'll try dropping it in an ultrasonic cleaner and seeing if that helps might just need to go ahead and order a rebuild kit thanks for y'all's help God bless.
On the rebuild, try this before final assembly: https://www.youtube.com/watch?v=Pnpn0O3L-Q8
On disassembly, do this test as well (?) shake the float 'n see if any liquid got into it (?)
