No the upper (small bolt) is holding the sleeve that the caliper slides on (the bushing is inside the caliper body), so you lubricate it still attached (i.e the piece the small bolt is holding doesnt move, it is the fixed part)
The lower sleeve will push out of the caliper body and you lube between the removed sleeve and the body of the caliper
