Welcome to the forum!
If it is a stock fuel pump, it will be located right in front of the air cleaner and is mounted into the cylinder head with 2 bolts. There will be a couple of fuel lines connected to it as well, one from the frame area (supply from fuel tank) and the second that will run up to the fuel filter which is just to the right of your air filter in the picture.
The stickers under your hood and on the fire wall will tell you what engine that you have. If it is a G54B it is the 2.6L, that is what my 1980 D50 Sport has.
There are a lot of very knowledgeable people on here, that can really answer just about any question that you could have about these pickups.
