Sophomore
So i went through and checked my fuse panel looking for a short as per this video: https://www.youtube.com/watch?v=9wLrTjeb9TY
couldn't fine anything there.
There is an in-line fuse near the battery and i had changed that already but maybe the housing is toast? I can't really see what it goes to but it does connect to the wire bundle that holds my headlight wires near the headlight relay.IMG_4840.jpgIMG_4839.jpg
I'm just not sure what else to check. Am I correct in thinking that as long as my relay is making clicks it's receiving signal from the switch in the cab?
it's just so weird that both went out together because to me they seem completely unrelated.
