Page 3 of 3 FirstFirst 123
Results 51 to 52 of 52
Thread: Electronic box under/behind lighter/ ashtray and on hump behind console?
  1. #51
    Ca
    1993 Dodge Ram 50
    Cchuckster,
    The '93 manuals I ordered just arrived ... cursory research shows ABS diag sections for 2WD/4WD 2.4 & 3.0 !!
    Also I stand corrected Manual lists only one fuse for ABS Controller > #20 .
    Couple more caveats,
    The G-sensor & Control module mounting drawings in the FSM are exact to Your posted pictures.
    Tortron -There IS a location drawing for a central locking module-
    More to follow Honored Posters, Always A Pleasure !!!
  2. #52
    Nevada
    That is one very nice truck. Paint job is very clean. Are you planning on keeping the plow on front?
    Tires and lift look nice too. Just a note on the front suspension. Maxing out the 4x4 fronts can lead to several issues. 1st is your camber will be off causing the outside of your tires to wear prematurely. 2nd and probably the biggest deal is cranking the torsion bars up to the snubbers or past will cause your CV axles to wear and go faster. If you 4x4 it will be even quicker. I like to leave about 3/8" gap between the snubber, so i still get up and down motion.
