Went with a hunch after looking at Your build sheet.
The large & small 'units' respectively are...
ABS control module, MB 822080
'G' (gravity) sensor, MB 822686
I think Claych is onto something.
I have a 90 MM v6 like you and do not have anything in that area. Mine is a 5 speed too. If you were auto the control box for that would be up under the steering wheel dash. I know that abs started to come into play after 92 i believe.
Get a better view of those part numbers and report back. All of those parts and wiring look like OEM mitsubishi, so its likely standard.
PS. early 90's Mitsubishi ABS systems were scary to use in bad weather. Plenty of 3000GT owners pull the relays, so they can have normal brakes. This is likely the same solution for Mighty Max owners.
