Results 1 to 25 of 45
Thread: 87 Ram 50 EGH 'build thread'
    Cant Say
    Dodge V6
    figured i would start a build thread
    my plan is to use a chrysler egh v6 and a NSG370 6 speed. the 3.3L is my choice, a great mixture of gas mileage and power.
    i will me going over what fabrications have to be done, what to use, where to buy parts, and what 'customizations' i did to personalize it.
    so far i have the following required things listed:
    -engine mount brackets
    -radiator with fans (no fan on engine)
    -nsg 370 transmission mount and crossmember section
    -custom driveshafts
    -custom exhaust system
    -rerouted intake
    -custom wiring harness
    -gauge cluster remap and adapter(s)
    what i am customizing:
    -reused factory muffler, modified to 2 1/4 inch inlet/outlet
    -custom center console and bucket seats: requires custom shifter
    -custom ecu tune
    -larger injectors
    -32" tires and 20" or 22" wheels
    -front leveling kit (montero control arms and keyed torsion beams)
    -custom gauge cluster with digital gauges, 140 speedo, and 8k tachometer, custom gauge face and color theme
    -custom interior recolor (black/green-orange colorshift with white accents and white stitching) leather upholstery
    -custom wrap (flat black with green-orange colorshift tribal stripes and gloss black / white-orange colorshift accent stripes)
    -Suspension/frame repaint (completely flat black and rubberized undercoating under the cab and bed and in the fender wells
    -'Sport II Limited' badging
    -spray in bed liner
    Budget: $15,000
    Wallet: Enough
    Estimate: about $5,000 in engine work, $5,000 in appearance customizations
    most of this build thread is going to be exactly how to put an EGH V6 into a power ram 50, which is absolutely ridiculous. and im sure someone else MIGHT do this sometime in the future. Maybe this will be a valuable resource to them. If not ill have this to look back on as a memory.
    Got any idea what it will look like when finished (?) have you seen any online images of something similar..? Do you have a sketch drawing or pic..? Hope you can finish early & under budget... Best of luck & enjoy the build brother Salteen...
    Aloha --
    George
    Edit: P.S. Your avatar is a guitarist (?) or a frontline worker spraying disinfectant for covid19 (?)
    Cant Say
    Dodge V6
    I have a large scale sketch, yes
    Its incomplete, still getting lines corrected and dimensions more accurate
    Gonna have a camper shell, huh..? Colors..?
    Cant Say
    Dodge V6
    probably body color, it already has the shell, just gonna redo the grooved tin in favor of smooth flat sheet metal.
    Cant Say
    Dodge V6
    maybe the metal color, not sure on it yet
    Cant Say
    Dodge V6
    update: the 4 cylinder is almost complete! ready to drop in so i can save some money!!!
    Ca
    1993 Dodge Ram 50
    And ???
    Cant Say
    Dodge V6
    And what?
    Ca
    1993 Dodge Ram 50
    oops, and pictures
    Cant Say
    Dodge V6
    Ah. Here.
    The block is honed, all bearings looked amazing, babit was still on all of them. I beleive it is an original 50k mile truck. Too bad it's so rotted out
    Cant Say
    Dodge V6
    The pickup was clean as could be, almost see through, no tarnish there!
    Cant Say
    Dodge V6
    Jet valve elimonators in! Also tapped my head bolt holes and rocker arm bolt holes
    just gotta give it a weapons grade clean and some port work, some tidying up in the valve bowls and it'll run super smooth
    Cant Say
    Dodge V6
    Already cleaned the valve bowls, I think I will try to port match the head to the gasket with a die grinder. Or, since I am V6 swapping, may just ignore it.
    Well, you've got the head off and it's half way there... the valve bowls are the harder part of the head mods.
    Cant Say
    Dodge V6
    Made a little free time sketch with some minor detailing, might me the start of the painting under my hood
    Cant Say
    Dodge V6
    New goodies! And I got an exedy clutch.
    Cant Say
    Dodge V6
    i see my thread is about as dead as a graveyard. may as well update anyways
    well, im not going as all out as i thought, but the V6 swap must continue! this is a very interesting engine platform. im going to try to run a carb on this engine and see how it goes.
    lets see, 3.3L V6 that has a 93 mm bore and an 81 mm stroke, 3.3 liters
    i am well versed in V8 engines now, so a 4.4 liter street V8 will use about a 650 carb at best. an edlebrock 500 will be plenty on the tiny V6.
    Nevada
    1991 Dodge Power Ram 50
    Confused. 4 Cyl going back in or a V6?
    It looks dead because everyone is watching tell we have questions, that's all.
    Cant Say
    Dodge V6
    Quote Originally Posted by B-Line View Post
    minivan V6 going in with a jeep 6 speed
    Cant Say
    Dodge V6
    well, its nice to know theres not much confusion
    Cant Say
    Dodge V6
    Lemme correct myself. I4 goes in until I have $$$ to rebuild minivan motor and a jeep tranny/ build a bellhousing and put a T5 behind it
    Nevada
    I4 sounds like a good plan.
