Results 1 to 25 of 116
Thread: Starting issues
Threaded View
  1. #11
    Xbox I was searching MB031704 which is what came up on several Mitsu sites for the 85 MM. I searched that number you have and I came up with an ignition lock. I was probably missing something. When I get a phone line I'll call your guy. My phone no worky. 19 days today. Still no help the lady I email with is sickeningly polite and unhelpful. Supposedly someone will be fixing the line tomorrow.
    Geez, I used that Mikuni fuel cut off wire for the fuel pump and it was hooked up to the starter by that Dodge mechanic. I though the starter wasn't supposed to have always on power? My head hurts.
    Edit-Duh I reread your post geez. My brain no worky well today. I was going to hook the starter to the 12v side of the ballast but I could not determine which one was because both indicate 11.8v when the key is on. I think the one on top that gets the b/wstripe wire from the 4 way splice is probably where it should go. The b/wstripe wire that comes from the switch is in the other harness and goes to the other side of the ballast.
