OK I got an inline tester I am not sure works. I wasn't paying attention and it has a 90 degree boot. I had to pull it off to get it on. #4 and #1 no light. Didn't try the others. I will be looking for one with a straight boot and longer lead.
Loosened up and re-tightened the grounds which were pretty new since I got new battery cables in the last 2 years. The one on the block and frame weren't as tight as I made them after. No effect. I also sanded off the rotor and the contacts in the cap. The Dist is new last year or so. No points Tort. Never fixed me one of them
I do not know how I might test the coil. I bought it new and it sat for a year or two before I installed it. There were no signs of a problem before now. I'll look up how to test it with my multi thingy.
Edit- I think my problems with how it runs or doesn't want to start after it sits or when its hot may have been electrical all along. Oh yea all fuses are good.
