Freshman
Mitsubishi mighty max steering wheel options?
Hey guys I just purchased a 1994 Mitsubishi mighty max and everything is running well it just has a messed up steering wheel and I was wondering what are the some good options for a replacement?
Doctorates Degree
Hi and welcome to mightyram. Got to answer your question with a question - OEM alternative or aftermarket? Guys use the Mitsubishi Eclipse wheel occasionally to keep the Mitsubishi DNA (looks decent and still maintains a factory-ish appearance) As for aftermarket there are plenty. Do yourself a favour and stay away from bargain basement wheels and steering hubs/bosses. A cheap MOMO knock off wheel for $20 will buckle with moderate pressure and the urethane grip will barely be anchored to the wheel rim and twist around in your hand. Most of the cheap bosses that claim to fit Mitsubishi and a few other cars will disable the horn function and not bolt down to the steering shaft correctly.
Freshman
Thank you for the response! I think that I am looking for an aftermarket steering wheel so I was wondering what are the best options for that? also i dont mind spending money on it because i purchased the truck for all of one dollar. thank you again!
Grant has the proper hub and ton's of nice steering wheels. http://www.grantproducts.com/
Freshman
I think I am going to get this steering wheel http://www.grantproducts.com/products/view/932/ and it says to use the 3390 installation kit. is there anything else im going to need?
