1992 MM 2.4 5sp
130000 miles
No CEL
Thanks to everyone and hope all is well!
I’ve searched everywhere and followed some write ups in regards to truck jerking on low gears.
Mainly on 1st to 2nd. Especially after cold start.
timing, fuel pressure, spark, all checked okay.
checked cat; not plugged
no CEL
no symptoms before it happened. Just one day it wouldn’t start.
new battery, same; replaced starter; fired up.
that’s when it started hesitating. When revving after
it suffers when cold but when warms up, drives okay-ish. Little to no hesitation
I noticed that the temp gauge doesn’t get to half even after a long idle or test drive
coolant temp sensor?
I wanted to seek help before I start throwing parts in.
mechanic mentioned MAF sensor, TPS, distributor, injectors?
thanks in advance.
