I posted a while back about a leaking oil pump gear seal. Before it was a puddle of oil. Now if you look at the cardboard under the truck there is a splatter of oil coming off the timing belt. On the 2 seals installed I seated them into the case which set back about a eighth of an inch this time installing the seal I seated it flush to the front of the case. On the rebuild I did not pull the front case off of the motor I only replaced the 3 seals and the o-ring. As you can see I have power washed the paint off the pulleys trying to find this leak it is driving me crazy. Any suggestions at All??
Thanks in advance.
