Welcome to the site. Here's a post with the general hose routing:
http://www.mightyram50.net/vbulletin...vacuum+diagram
Plus here's another below that shows the color coding of the hoses and 'T's. It's for the 2.6L engine but most of it should apply to the 2.0L. If you find a difference, just ask.
I believe some 'T's may have restricted ports, so if the owner didn't provide them, you may have to get them and the hoses from a wrecking yard. Good luck.
Wow! that has to be the most detailed vacuum diagram on the vacuum setup I have seen, sorry for the quick threadjack but what book is that from? my factory chrysler books only show the functional schematic showing how the system works. unfortunately it appears that the OP is in comifornia like me and almost all counties except 2 or 3 require smog inspections every 2 years with all counties requiring it upon transfer of ownership. I might have some extra vacuum line stuff if the OP cant find a complete vacuum harness although everything I have has came from the 2.6L and I am unfamiliar with the 2.0 so I may not have everything needed for it
