B-Line Performance
I’ve got a 4x4 and am running 30’s on mine. I’ve seen several others run 31’s with stock lift. If you want a wider wheel look at the slightly newer Montero wheels. They look and fit well.
Sophomore
Thank you sir. Im really liking some pro comp 6x5.5x9 27's a guy bought and they wont fit his rig. If i can fet tgere beforesomebody else gets them im golden. Already have sone decent 265/70R17s for on tgem. Have to crank up t bars and hope for the best. Should look 100% better than stockers. -6mm offset will give it a wide wicked stance and saying my prayers i get here in time. If i get them, gonna mount up 2 on the new rims and test fit for clearance. They are 31.6" tall and 10.6 wide. Will take before and after pics. Wish me luck thanks.
Sophomore
Sophomore
Not 27's ....17's wth am i saying with the 27's typo. Seems like im gonna be the guy to get these rims i like. Are yhete any pics orvideos of tge t bar lifting on a mighty max or dodge d 50 power ram? Im not finding and visual aids anywhere.
