I'm looking for some help with the ignition system on my 88 2.0 with a Weber carb. My truck suddenly died and would not turn over when I tried to crank it. So I replaced the stater. Now the starter spins and turns the engine but I have no spark. There is power on the coil when the switch is on. I have replaced the coil and the distributor still no spark at the coil or distributor. The only other component in this system I am aware of is the balast resistor. Is this correct or is there something else I'm missing? What should the impedance on the balast resistor be? Where can I buy one for an 88 the only ones I see for sale are for 84-85 & 87.
