Results 1 to 4 of 4
Thread: 88 no spark
    Lexington nc
    88 no spark
    I'm looking for some help with the ignition system on my 88 2.0 with a Weber carb. My truck suddenly died and would not turn over when I tried to crank it. So I replaced the stater. Now the starter spins and turns the engine but I have no spark. There is power on the coil when the switch is on. I have replaced the coil and the distributor still no spark at the coil or distributor. The only other component in this system I am aware of is the balast resistor. Is this correct or is there something else I'm missing? What should the impedance on the balast resistor be? Where can I buy one for an 88 the only ones I see for sale are for 84-85 & 87.
    Hmmm, if you've got power either side of the resistor IDT that is the problem. Did it suddenly die or have you changed something recently? If the ballast resistor has failed it'll show typical signs - will start, runs for a while and then the engine dies. You come back later - same thing. The ballast will get white hot, easily hot enough to burn your fingers. The ballasts for Mitsubishis of this era are all the same. Even if the coil is weak it will still generate spark and fire under normal load. Check your timing belt and your timing marks (belt could've stripped a few teeth - it does happen) do a visual on the plugs. Make sure you don't have a dead short somewhere attached to the ignition circuit like the fuel cut wire to the stock carb set up.
    Lexington nc
    Thanks for the suggestions I'll check it out. Any idea where I can get a pin out of the stock carb connector?
    The fuel cut solenoid wire is the same as all of the ignition system power wires - a black wire with a white stripe. What are you using for power to run the Weber fuel pump? Is it still pumping fuel? - if not there's every chance the faults are related.
