I'm having a similar issue. The disy was changed, new coil, wires and plugs. The coil was throwing some strange voltage. 12v on all 3. So I pulled it and put one off an old ram charger just to try it. It will sputter on starting fluid. Did a comp test, reset disy timing. Then just to be sure to make sure I wasn't 180 out I move it 180. Pulled fuel rail and sprayed carb cleaner through it. Pressure reg won't shift though but it seems stuck closed which should make it run rich if I'm not mistaken. Someone tell me where I went wrong. Also, the truck has been sitting in the woods for about 3 years. It's new to me. And it's about 2 hours away and I can't get it towed. I've hooked a winch to it and uprooted a tree. I've jacked each week up and pulled it and got the brakes free spinning and it still won't budge with a winch. It's a 4x4 and hubs are unlocked, it's in neutral and I'm at my witts end here.
