The G63B engines had different oil pump assemblies - the later ones had bigger pump gears and were an improvement in oil supply and pressure over the older ones. IDK if there is a similar situation with the 4G54 oil pumps... it would explain the elevated oil pressure readings (or maybe there's an accuracy issue with the test gauge)
